Results 1 to 4 of 4
Thread: Any experience with cleaning this?
    UAMCC Treasurer John Orr's Avatar
    Chesapeake, Virginia
    710
    Default Any experience with cleaning this?
    This structure is made of some type of plastic/resin or fiberglass. The problem is that it has not been cleaned since construction (13 years) and the white silicone caulk is black and being carried down the panels. I need to clean the caulk - as well as the panels.
    Here's what I've tried on the panels: Simple Green, full strength, Krud Kutter and an industrial non-butyl cleaner supplied by the property manager. All were applied with a car-wash brush and rinsed without pressure. The streaks were reduced, but shadows remained. I also tried a Magic Eraser (in a small, inconspicuous area) and it did a fair job of removing the shadows.
    On the caulk, I used varying %'s of chlorine - including 12.5%. It lightened the caulk to gray. Even with scrubbing, I could not get it white.
    I spoke with Mike at Eacochem and he's sending me a care package.
    UAMCC Board Member/Treasurer
    757/718-5442
    Default Re: Any experience with cleaning this?
    Once caulk is blackened, John, it stays that way. At least that's been my experience throwing everything at it. The panels probably need a resto acid. GS Restoration or OneRestore would be what I would probably go to.
    710
    Quote Originally Posted by PressurePros View Post
    Well, I hope that Eaco Chem has a solution. They sent me before and after pics of a building that looks similar, but... BTW, in addition to the cleaning, the customer is wanting an estimate for waxing!
    757/718-5442
    UAMCC Member Innovativewash's Avatar
    cream ridge nj
    370
    Mike will have your answer on this. If you apply Glory BC and a little scrubing this should take off the black streeks from caulk bleed.
    James VanHandel
    All of new jersey
    609-738-3100
    innovativewash@aol.com
