+ Reply to Thread
Results 1 to 10 of 11
Thread: advice on roof cleaning with surface rotary PW
    Jul 2010
    6
    Company
    Warwick Builders
    Default advice on roof cleaning with surface rotary PW
    I am a roofing coating contractor who has two identical 13hp cat pump 3500 psi - 3.5 GPM to 4gpm PW's.
    I was looking at the mosmatics surface cleaners and found one for sloped roofing which has adjustable wheels and also looking at a 20-30 inch model for flat EPDM and other roof semiflat surface for coating cleaning and prep purposes. I am looking for industrial grade and cost is not an issue.
    Is there a way to combine output of two pumps to get a 3500 psi 8pm? or is that not going to work?
    Thanks for help ahead of time...
    Default Re: advice on roof cleaning with surface rotary PW
    When you say coatings, will the coatings stand up to the pressure. I am sure someone will step up and help you, but yes machines can be joined.
    Anyone?
    Jul 2010
    6
    Company
    Warwick Builders
    Quote Originally Posted by JL Pressure View Post
    Anyone?
    Sorry - i see how that was confusing - i meant we apply water based coating after the areas are prepped by water pw...
    WE are using two identical pw units rated at a 3500 psi 13hp Honda/CAT pump at 4.0 gpm (nozzle size 4.5) to prepare all types of roof surfaces from Ashpalt cap sheet to metal corrugated and all in between. No clay tile. We are based in virginia beach, VA.
    Jul 2010
    6
    Company
    Warwick Builders
    Is it as simple as a 3/8" tee with some sort of compensator ?
    UAMCC Moderator John-Clean County PW's Avatar
    1,680
    Long Island NY
    Quote Originally Posted by Warwick Builders View Post
    If the the machines are rated the same then you can do it. You just need that special T that only lets the water go thru it but not back down into it. Michael Hinderliter owns this Powerwashing store http://www.dcs1.com/ and if you search on there you will find it. I have two of them and we almost always are joining our 2- 4gpm machines when it comes to those larger jobs.
    John Tornabene
    631-544-4971
    Long Island NY
    www.cleancounty.com
    UAMCC Member
    PWNA Member
    UAMCC Contractor Member
    Feb 2009
    190
    Warwick NY
    Company
    Valley Mobile Cleaning, Inc
    If both machines have a "trapping" unloader then you can just "T" them together. If they have "flow" unloaders then you will need a check valve in each line. That is what John is talking about, and DCS can help you with getting one already amde up.
    Doug Tripp
    845 544 3645
    Jul 2010
    6
    Company
    Warwick Builders
    nice thanks
    Jul 2010
    6
    Company
    Warwick Builders
    Thank you, any advice or experience with mosmatics or other brands ?
    Feb 2009
    190
    Warwick NY
    Company
    I use a Mosmatic swivel and spraybar on my surface cleaners and like them, never used their roof cleaner.
    Doug Tripp
    845 544 3645
    Jul 2010
    2
    North Florida
    Company
    HYDRO-TECH SERVICES
    Hello, EPDM PVC TPO membranes hold up well but I think carlisle's guidelines are 2500 psi max. I have used 3500 psi but with a adjustable castering type spinner. I wouldn't use a floater due to membrane wrinkling and or de-lam that will leave ridges or high spots that if caught by spray arm will tear membrane and or bend your spraybar. LOW Low heat is also OK but I forget the spec's.Elastomeric coatings [water base hold up like crap at least in the south your customer will think you poured milk down their spouts or a white cloud will form in the stormwater pond.Think of the millions of flat membrane roofs on highrise or other facilities I have and made $$$$$$$$$$$$$$$. JL pressure, your already up there why not plug the membrane ? Also a gray scale reflecivity chart is a good selling tool the whiter the membrane the more savings in elecricity, that could add up to thousands a month for huge facilities.... Regards Jeff
    Hydro-Tech Services Jeff Renn 904-703-0982
+ Reply to Thread
Tags for this Thread
