I have 8 large 3 story buildings where I will be doing the roofs. The buildings have NO gutters, not much of a pitch. They are long 150-200. What is the best to cover the ton of shrubs they have on the ground
I want to cover shrubs 100%. CLEAR PLASTIC sheeting, if I put that over the shrubs, will the heat being contained under the clear plastic, suck the life out of the top of the shrubs and brown the shrubs out?
What about Blue tarps? is that better or worse? Problem with blue tarps it will cost me a arm and a leg, for all the tarps I will be needing. I figure having at least two guys washing maybe three up on the roofs and 2 o3 guys on ground spraying water and moving tarps
I rather use plastic sheeting, it will be much cheaper, but years ago I painted a house and left plastic sheeting on shrubs during a hot day for like 5-7 hours and it sucked the life out of the top of the shrubs
What do you roof cleaning guys use?
Thank you
