+ Reply to Thread
Results 1 to 10 of 17
Thread: Roof Cleaning Pros
    Default Roof Cleaning Pros
    Hey guys! Good to be back on here. We cleaned this Evansville roof using our non-pressure roof cleaning method, and just look at the results! This roof took us 2 hours to thoroughly clean.
    Precision Power Washing & Non-Pressure Roof Cleaning Evansville, IN 270-860-7894
    Kevin O'Bryan; Owner/Operator
    UAMCC Contractor Member Rsuds's Avatar
    Sep 2009
    154
    Bucks county Pa.
    Company
    Rolling Suds Inc.
    Default Re: Roof Cleaning Pros 270 860 7894
    looks good.
    Pressure washing in Pa.
    Brian Wendling
    Rolling Suds Inc.
    www.Rollingsudsinc.com
    Thanks Brian!
    Senior Member
    103
    Tampa Florida
    Company
    Apple Roof Cleaning Tampa
    Nice roof cleaning work, for an Irishman O'Bryan. I wonder how long the roof cleaning season is up there in Evansville Kevin ?
    It would be nice to clean roofs into the early winter ?
    Member
    46
    Hampden Mass
    how much solution did you use? I am wondering if I am using enough when I apply.
    Senior Member
    103
    Tampa Florida
    Company
    Quote Originally Posted by bobmez View Post
    I will answer for my friend Kevin. Apply enough solution to completely wet the area of the roof you are doing. Wet it down, and move on. It is a common roof cleaning mistake to sit there, and continue spraying the roof until it cleans. Simply wet it down good, then move on. Depending on outside temperature, it should clean in under a 1/2 hour. IF it does not take, hit it again, and wait.
    UAMCC Member Innovativewash's Avatar
    370
    cream ridge nj
    Company
    Innovative pressure cleaningLLC
    Whats the lowest temp do you guys treat roofs in? Im still going in 45-50deg weather here in NJ.
    James VanHandel
    All of new jersey
    609-738-3100
    innovativewash@aol.com
    UAMCC Moderator Scott D.'s Avatar
    1,013
    Houston, TX
    We clean unless there is ice on the roof. 9Which rarely happens here in texas.)
    Scott Davis
    Confident Roof Cleaning
    UAMCC Charter Member Beth n Rod's Avatar
    749
    Maryland
    Company
    See Dirt Run!TM Inc.
    Please leave your phone number out of the title of the post....you are in that area that will get your post pulled as spam.....If it is in your signature, you are fine. (the same holds true to key words and city and state)
    Let's keep the forum full of information.
    THANK YOU!
    Beth
    Log Home Maintenance & Restoration, Decks & House Washing
    Beth Borrego & Rod Rodriguez
    Office: 301-540-1243
    Germantown, MD * MHIC# 86481 * VHIC# 2705-126609 * BBB
    The Grime Scene BBS Forums
    UAMCC Vendor Member Ron Musgraves's Avatar
    2,403
    Quote Originally Posted by Beth n Rod View Post
    THANK YOU!
    Beth
    Maybe the forum should have and area for SEO?
+ Reply to Thread
