Results 1 to 6 of 6
Thread: New/used pump im picking up
    1,114
    Default New/used pump im picking up
    I am picking this pump next week when I have a job in the area. Right now it is powered by a 3 phase electric motor but will prob resell the motor seperate and put a 20hp gas motor on it. Picking the whole setup for $200. Yes, it is 17gpm !!!! I cant wait to get it going. It going on my condo complex wash rig along a 12gpm(after I put in a new bearing) a 8.5gpm and 2 - 4gpms. Got 6 huge complexes this spring already on the books 15 open bids still out and putting new bids almost every day.
    UAMCC Treasurer John Orr's Avatar
    Chesapeake, Virginia
    710
    Default Re: New/used pump im picking up
    Hey Florin, The SFD called, and they want their pump back!
    UAMCC Board Member/Treasurer
    757/718-5442
    1,114
    If a wildfire breaks out in my neighborhood, my house will be well protected.
    It will be limited where I could use that machine due to water flow but for condo complexes I beleive will be a perfect fit. Gonna have to put my fire hydrant use permit to use more often.
    UAMCC Board of Director Lonnie Greenwood's Avatar
    May 2009
    deltona fl
    581
    Quote Originally Posted by FLORIN View Post
    hey i have a 40 horse power that would go good with that
    Lonnie and Nikki Greenwood
    ANR Pressure Washing, Inc
    Deltona, Florida
    386-232-4388 Office
    386-473-6809 Cell
    lonnie@anrpressurewashing.com [url]www.anrpressurewashing.com
    serving the following states FL GA SC NC TN VA TX Or and states in between Go UAMCC!!!!!!!
    Member Russ Johnson's Avatar
    Dec 2008
    Louisville, KY
    59
    You're going to need a massive pulley on the pump to spin it slow enough (750 rpm). Here's a spec sheet on it. According to the sheet, it's rated for 14.6 gpm continuous @750 rpm and 17 gpm intermittent @ 890 rpm.
    Southside Equipment, Inc.
    Louisville, KY
    502-231-6506, 888-243-6506
    1,114
    Quote Originally Posted by Russ Johnson View Post
    It has a big pulley on there now with the electric motor but will check what I need when convert to gas motor.
