Results 1 to 10 of 10
Thread: Bleeding brick
    Default Bleeding brick
    Did this brick wall at a condo complex on Monday. Used NMD80 and applied a bajillion times till all the white stuff was gone. Wall looked awesome. Got a call yesterday that it does not look good anymore. I went there today and there is white powdery stuff coming out of the brick. You can even rub it off with a brush or finger.
    Whats going on here?
    Reapply nmd80 or do I try something else?
    Will it keep bleeding out?
    Dont get much brick around here so am kinda lost.
    the post and close up pick is the powder that is on now.
    Default Re: Bleeding brick
    A couple of questions first, does the wall hold back a lot dirt and how high is the dirt on the back side of the wall? How long has the brick been put up?
    Roger Gothorp
    Carolina ProWash
    Florin, You need to read up on Masonry problems and fixes . There are a few way's go an approaches. Stuff leeching out means a couple of things. Not just efflorescence
    Go to a few sites that sell product and read up on the type of problem you have. You can send them your photo's too .
    Diamond Jim's LLC
    Wood & Stone Restoration
    Pressure Cleaning
    Waterbury CT
    James Foley
    Quote Originally Posted by FLORIN View Post
    Florin i think thats calcium coming out and i think you would have to clean off then seal not 100% sure but can ask a buddy that would know if you like.
    Marko
    CLEANHOODS formally S&M Cleaning Services since 1997
    call 24/7>>>>>>> (828)632-7688 office
    High quality exhaust system detailer...emergency services available...fair rates....guaranteed inspection approval !
    Owner: Marko
    Visit Cleanhoods at:
    http://www.facebook.com/pages/Cleanhoods/186427068726 or http://twitter.com/ Or E-Mail cleanhoods2002@yahoo.com
    Quote Originally Posted by RogerGothorp View Post
    Roger Gothorp
    Carolina ProWash
    On the backside the dirt is up to just under the cement cap. I am also getting it on the posts as well which have no dirt.
    It was built in 2003. While I was doing the cleaning a neighbor stopped to talk and said the wall turned white within 6 months of being built.
    Agreeing with Marko, I have always been told that if you don't seal the brick then even if you clean it it can come back, not always but sometimes.
    On the wall...if the dirt is piled up in back, there is always going to be the potential for moisture to travel through and bring the salts and minerals out the front.
    What would you expect to happen if you seal the front of that brick at this stage of the game?
    What's on top of that column structure? Is there a crack? Moisture has gotten inside again somehow to cause that.
    Roger Gothorp
    336-516-6139
    Quote Originally Posted by Carolina ProWash View Post
    Thanks for the response Celeste. Also thank you very much for taking my call about this project a couple weeks ago Roger.
    I am confused about your sealing question.... Are you suggesting that I might need to seal it?
    LOL, no I wasn't suggesting that - someone else did. What I was asking - from a logical standpoint, was.....if the moisture travels from the DIRT side of the brick out the front......what do you suppose the outcome is going to be if you just slap some sealer it? My guess is ugly white BEHIND the sealer....oops!
    With that said, there are remedies (sealers & fortifiers) that will penetrate far enough into the brick that it won't make it to the visible exterior. Realistically, sealing should have happened a long time ago - like at construction. Do they experience this regularly or have you had an exceptionally wet several months like we have here? I'd be willing to bet that during drier seasons, it's not as obvious a problem.
    Roger Gothorp
    336-516-6139
    Florin the white is calcium and/or salt and the bleeding happening is from not sealing the brick, clean the brick and seal it.
    They make a sealer/cleaner for that.
    Look around like at old churches you will see white there and the building is not leaking "moisture" in the church or at the top eather ,thats probably calcium.
    Now when new brick does that and the problem may be a moisture problem(like Carolina said) so thats salt.
    The salt content may be from the brick AND/OR the soil on the barrier wall.
    For the collums clean and seal,but the barrier wall now you would have to dig the dirt up from the back of the wall and clean the brick and use a sealer behind and in front.
    But if you would like i can ask a buddy that has the know how on this type of work.
    Or the customers just have to deal with it until the salt content exhausts itself which could take years.
    Marko
    Owner: Marko
