+ Reply to Thread
Results 1 to 9 of 9
Thread: Concrete with tar
    UAMCC Charter Member
    Oct 2009
    43
    Default Concrete with tar
    This is a concrete balcony on a commercial building. They want to start using this outdoor area. Looks like tar paper asphalt and tar were on it for quite a while. The tar paper/asphalt will be removed prior but they want the concrete cleaned. Any suggestions on best method to clean this?
    60 x 20 ft
    Thanks
    Mike Fox
    Fox ProWash
    UAMCC Contractor Member GrimeBusters's Avatar
    Aug 2009
    671
    Company
    Grime Busters Pressure Washing, LLC
    Default Re: Concrete with tar
    I've removed tar successfully, but more times than not the concrete will remained stained. If the customer is expecting like new concrete look, pass on it.
    Senior Member cleanhoods's Avatar
    554
    western North Carolina
    Company
    Cleanhoods formally S&M Cleaning Services since 1997
    After you clean the concrete to cover the stain use concrete stain to cover the stain.Hope this makes sence,lol.
    Marko
    CLEANHOODS formally S&M Cleaning Services since 1997
    call 24/7>>>>>>> (828)632-7688 office
    High quality exhaust system detailer...emergency services available...fair rates....guaranteed inspection approval !
    Owner: Marko
    Visit Cleanhoods at:
    http://www.facebook.com/pages/Cleanhoods/186427068726 or http://twitter.com/ Or E-Mail cleanhoods2002@yahoo.com
    Oct 2009
    43
    Thanks to all!!!
    Mike Fox
    Fox ProWash
    Oct 2009
    43
    Follow up. I am planning on painting this concrete balcony. I cleaned off all the asphalt and steam cleaned the concrete. There are still some areas that are holding tar and oils in the concrete. I know this because when wet some areas have beading water. Any suggestions for removing this before I paint it?
    Thanks
    Mike Fox
    Fox ProWash
    Aug 2009
    671
    Company
    Any areas left that still contain oil or petroleum products will make any coating you plan to apply fail.
    Is the oil pumping up out of the concrete, or is it all on the surface ?
    Oct 2009
    43
    Some areas are pumping up.
    Mike Fox
    Fox ProWash
    Aug 2009
    671
    Company
    The summer heat will only promote the oil or tar to keep "pumping" to the surface.
    Jul 2010
    6
    Company
    Warwick Builders
    You need a product like ASTEC Bcs-4 spec which is compatible with the tar/asphalt emulsion, best use ASTEC ASPHALT primer, etc, there are certified astec installers across the country
+ Reply to Thread
