Results 1 to 10 of 16
Thread: Need More Hose!
    Industry Veteran Carlos's Avatar
    4,394
    Default Need More Hose!
    I am playing around on my set up and I am looking to add another 250+ feet of hose which means adding another reel. Right now I have 2 reels - one for supply to the tank and the other for the gun.
    This may be dumb ? but can I add another summit reel and stack it on the existing one...plumb it so that both reels feed just one gun. I was looking at my set up for about all 10 minutes and couldn't see how this could be done but thought..."hey...I will ask the pros here on UAMCC"!!
    Or do I just need to buy a reel that can handle 500+ feet? I was looking at the SM 30 ~ which I think holds around 600 feet but its base is wider and I dont have much room on the single axle due to the tank and tool box that is on it.
    Any suggestions?
    4,394
    Default Re: Need More Hose!
    As a footnote to my post above...I am changing my target market to focus in on commercial primarily. My set up sufficed in the residential arena but I need to make some changes to my set up.
    Couple things to consider. Friction loss is #1. The more hose, especially 3/8" hose, the more PSI and GPM you'll lose. Volume flatwork and maximum profit happen with high GPM and optimal PSI. And as Jim Gamble has taught me, high heat is your best friend doing garages. (All I wanted for Xmas was a 2.2 MILLION BTU burner)
    The second thing I'm thinking of is I can't imagine hand cranking 500' of hose up several times a night.
    Since I invested in my electric Hannay reels, I'll never consider anything else.
    I'll post pictures of my set-up tomorrow.
    Attached Files Attached Files
    4,394
    Quote Originally Posted by GrimeBusters View Post
    Yes the thought of cranking all that hose will be a pain in the ***
    The electric Hannay is an option also...I never thought of that Jim. Thanks.
    I am bidding on some large storefronts here in the Bay Area and if my estimates are correct...some of them will have to have at least 400' of hose on the deck!
    1,114
    I have my main reel that is plumbed with the spindle with 250' of hose and then I have 2 more reels that the hose is not plumbed in. It just has quick conects on each end and I just pull it off the reels and connect to main when needed. The other 2 reels are just air hose reels and I keep 100' on each.
    Carlos instead of stacking reels and buying the 2nd one, to accommodate more hose, why don't you just buy a bigger hose reel, take off the reel thats to small. I have some that hold 300 ft and I have a couple that hold 400ft
    Commercial flat work, do you have at least 8gpm, it really makes a difference
    UAMCC Contractor Member
    Jul 2009
    Toano, VA
    96
    Carlos,
    Like Florin said use the extra reals and with them portable you can carry them out 200 or 300 feet to where you need them.
    JL is right about the bigger machine. We bought a newer trailer last fall with a used 5gpm machine. We put our newer 5gmp on it and then we plummed them together for 10gpm. It walks right through the sidewalks. We have it set up for 10 gpm to use on the surface cleaner and then we can swithch it to 5gpm on 2 hoses so 2 guys can be rincing at the same time. We can go twice as fast now.
    This will work good, I got a verbal agreement on about 15 medium to large shopping centers twice a year. I hope to get the signen contract this wek or next.
    Lenny Schrecengost
    Lenny's Power Washing
    Toano, VA, east of Richmond
    The last job we had over 1500 hundred feet of hose out, thats not including low pressure hose. I dont plumb hose reels to machines I quick connect and pull out what I need its easier for us that way. I would say get the biggest hose reel you can get on the trailer and fill it up you can never have enough hose on your trailer.
    UAMCC Member Innovativewash's Avatar
    cream ridge nj
    370
    Quote Originally Posted by splashandash View Post
    Carlos,
    If you have a 400ft lenth of sidewalk to clean you need two hose reels holding 250ft hose each. Park in the center of the job, work both ways, you need two machines or sometimes we run two surface cleaners from a 8gal min machine.
    James VanHandel
    All of new jersey
    609-738-3100
    innovativewash@aol.com
    cream ridge nj
    370
    Quote Originally Posted by Innovativewash View Post
    Carlos,
    Oh yah!!
    purchase electric hose reels. They are worth every penny. After pushing around surface cleaners all night the last thing you or your guys want to do is crank.
    James VanHandel
    All of new jersey
    609-738-3100
