Results 1 to 10 of 10
Thread: Downstreaming
    UAMCC Charter Member
    Oct 2009
    43
    Default Downstreaming
    I am interested in DS and have a quick question. I have 8.5GPM 3000 PSI system. I have a Hi-draw injector but was curious where I must introduce this to the system? Should it be directly after the pump or can I install further down by the hose reel?
    Thanks
    Mike Fox
    Fox ProWash
    Default Re: Downstreaming
    Some guys prefer putting it at the hose reel. We place ours directly after the pump. The key for good DS results are having your entire system tuned for it. (< 200' of hose, hi draw injector, the right size hose for your output, the right size orifice in your gun and of course the right size orifice nozzles)
    UAMCC Contractor Member Rsuds's Avatar
    Sep 2009
    Bucks county Pa.
    155
    I have also used them with a pump hooked up to them so you can pump more soap threw them. Most put them after the pump.
    Pressure washing in Pa.
    Brian Wendling
    Rolling Suds Inc.
    www.Rollingsudsinc.com
    UAMCC Charter Member Guy B's Avatar
    Aug 2008
    Dublin N.C.
    1,076
    We have ours at the reels, it's where the chem tanks are.
    Ball valves at my reels, which allow us to attach our Allison Super Sudders when we are downstreaming, then we disconnect them, turn up the heat and spinners away.
    Aug 2008
    Dublin N.C.
    1,076
    Jim, I just started disconnecting the ds'ers when we use the surface cleaners last week. I could really tell a difference! Good Tip!
    400 PSI in my case. Less restriction through the coupler. I'll post a picture of my set-up. I'll try and remember to take the picture tomorrow.
    Another good tip is never downstream with your heat on. Cuts down the flow.
    Industry Veteran Carlos's Avatar
    4,394
    Quote Originally Posted by GrimeBusters View Post
    I would be interested in seeing this Jim. I am moving some things around on my set up and the Ball Valve set up is worth looking at I think! I would appreciate it.
    Quote Originally Posted by Carlos View Post
    I'll get the pictures taken tomorrow and post when I get home.
    UAMCC Treasurer John Orr's Avatar
    Chesapeake, Virginia
    710
    I've actually used a ds'er with 400' of hose...I just quick connected it at 300'. Normally, I have the ds'er quick connected just past the coil.
    UAMCC Board Member/Treasurer
    757/718-5442
