Originally Posted by
Carlos
Gotcha...and I suspect the reason for this is to NOT allow the chems down in the gravity flow drain system which ultimately drains out to the curb in front of the house which in turn discharges to a common drain system aka as a sewer drain? Thats correct, but mostly to not let any of the solution to run off into the grass or landscape Around here most people arent to worried about runoff to a drain unless your doing a commercial property.
Fair enough...even an old dog can learn a new trick.
Okay, so let me ask this ~ why not just sand bag the hole at the downspout...allow the water and chems to "spill" over at the gutters if you will? Your ground guy is rinsing continuousy from the gutters down making sure that the chems on constantly moving down the house with a final destination into a landscaped area that was totally presoaked with water at the beginning of the job?
