Results 1 to 7 of 7
Thread: Commercial Building Wash
    Junior Member Darl Hite's Avatar
    Apr 2009
    11
    Default Commercial Building Wash
    Ok all of you building wash gurus. Went to look at the building pictured below. It is a concrete 2 story building that is showing mostly dirt running down from the top cap. My question is can this be cleaned with a normal house wash mix from the ground and rinsed or do you have to get up close and personal using a lift and pressure wash it off or do you have to use some sort of acid?
    Thanks for any info.
    Darl
    UAMCC Moderator
    Maryland
    424
    Default Re: Commercial Building Wash
    Based on the landscaping and everything else involved in the job I'd do it from a lift. You can use a good house washing like Power House and SH to clean this in most cases. Some times you might need to use an acid but it all depends on what the building is made of and exactly what your removing. If it's paint oxidation or heavy carbon deposits I'd use Heavy Duty Restoration cleaner from Prosoco.
    If you have any more questions give me a call.
    Henry Bockman 301-216-9675
    Henry's Housework Inc & Commercial Restorations
    13433 Tilford Court Germantown, MD 20874
    UAMCC Contractor Member bigbadwolf's Avatar
    Jun 2009
    Deltona FL
    232
    I would use my house wash and spray from the ground and I would say it would come clean no lift involved.
    Bryan Otten
    Action Plus Pressure Cleaning Inc.
    www.actionpluspressurecleaninginc.com
    e-mail ....action_plus_pc@yahoo.com[/FONT]
    1-386756-0630
    I second the lift.... with masonry being so porous a shoot and rinse probably isn't going to yield the best results.
    TimberSeal, LLC - Greg R
    Toll free : (866)-WOODCARE
    www.timberseal.net
    Deck Cleaning & Sealing Indiana
    Snow Plowing & Salting
    Visit us on FACEBOOK
    www.facebook.com/timberseal.net
    DO A TEST SPOT before bidding porous concrete can be anything from a simple house wash mix to heavy restoration like Henry said
    TEST SPOT
    UAMCC Member Innovativewash's Avatar
    cream ridge nj
    370
    Quote Originally Posted by JL Pressure View Post
    TEST SPOT
    We just did a building like this and the windows were stained .So we ended up using Safe restore. Now safe restore will kill plants so look closely at your surroundings.Allways test! You may get away with pumping 12%SH strait on. Oh buy the pics you need a lift it will cut your time down and you will get a better job. If you are not sure about taking on a job of this size, look for a partner who can show you the ropes the first big building out.These are money makers . So go for it!
    Jimmy v
    James VanHandel
    All of new jersey
    609-738-3100
    innovativewash@aol.com
    Moderator & UAMCC Contractor Member Carolina ProWash's Avatar
    733
    Monica - Please note, the companies on this forum ARE professional cleaning companies so suggesting getting an expert or a pro tends to make it look like you're not comprehending the reason for the post?
    Roger Gothorp
    336-516-6139
