Results 1 to 5 of 5
Thread: Stripping
    May 2009
    1
    Default Stripping
    Hi guys we are based in New Zealand. We do a lot of general washing but our main line of work is timber restoration. When you guys are talking about stripping is it a chemical stripper or a surface cleaner that you are using to remove a stain? If the house has a stain and the client is requiring a oil application we chemically strip the old stain totally of the house. When the timber just silvered off over time we use a surface cleaner. What I would like to know is how do you guys apply the stripper, we use a pressure pot.
    1,114
    Default Re: Stripping
    Quote Originally Posted by ecowash nz View Post
    Whats a pressure pot?
    When you mention surface cleaner... are you talking about some type of solution or an actual concrete surface cleaner?
    We use a shurflo pump setup or downstream to apply depending of the type of stain. We use F-18 or HD-80 wood strippers which are a sodium hydroxide based products.
    UAMCC Contractor Member The Cleaning Doctor's Avatar
    Jun 2009
    Clarksville, TN
    265
    A pressure pot allows you to set a bucket in it and you pressurise it with an air compressor and then you can spray from the spray gun. I have seen one used for spraying deck stain. Sweet setup.
    The stripper is applied via a dedicated pump like Florin said and some even use a pump up sprayer.
    Pat Motz
    931-933-5421
    The Cleaning Doctor
    Tennessee Wood Restoration
    Roof Cleaning Clarksville, TN
    UAMCC Charter Member tegrey's Avatar
    Canton, Ohio
    984
    Ecowash nz,
    To answer your questions. Stripping is the chemical or physical removal from a substrate for re finishing or painting. We normally use a chemical stripper applied by pump us sprayer. Some more caustic then others. Some cleaners as F-18 may be downstreamed on concrete. It depends on what products we use. A few of us here are painters. Therefore most would not use a pressure pot. I hope this helps.
    Our Passion is Coatings,
    Our Obsession is Service!
    Terry Miller COO
    Tegrey Family of Coatings inc.
    330-418-8955
    Senior Member
    Dec 2008
    Reading, Pa
    365
    I was using ACR's products as well as a few others, but did not find it to work as well as I had liked to. It was not bad, but it just did not fit my mold. What I did was start some testing on some woods I have at home to kind of dial in my ratio numbers to get the outcome I liked.
    The only time I ever used a pressure pot was with my HVLP. It worked out well for the kind of finish I was performing on high end new construction.
    As far as applying strippers, if I can help it I will be DS it all the way, but ofcoarse every job has different issues to deal with. Can not apply the cookie cutter scenario to everything in this industry.
    Colonial Power Washing and Painting by Sutton specializes in professional Pressure Washing Services and Roof Cleaning in Reading PA
    Make us your go to Pressure Washing company on FACE BOOK today!
    Contact us for a free estimate or consultation at:
    484-334-1311
