THE ALLISON CYCLONE SYSTEM
The Roof Cleaners Dream Machine - Hi-Volume Chlorine Flood Pump
Regular Price $2,795.00
This Month - $1,695.00
Cart or Base Plate
Comes with 20' of 1-1/4" plastic reinforced clear inlet feed line and 20' of 3/4" soft-flex return line and clamps.
The operator can 'throttle' the amount of chemical flow and adjust the pressure in seconds.
Single or two gun operation is standard and 4 gun operation is possible with the addition of two more valves.
The durable Cyclone pump is constructed of chemical resistant components that will give
the operator years of trouble free service when properly maintained.
Gear Driven Diaphragm Pump, Adjustable Pressure Regulator, Manual Dump Lever, Dual Ball Valve Outlets, Pressure Gauge, Can be Run Dry, Self-priming, Large Capacity Oil Bath, Quick Drain Oil Plugs, Chlorine & Caustic Ready, 316 Stainless Bolts, All Stainless and Polypropylene Liquid Handling Parts, Single to Four Gun Operation, 6 HP Kohler Industrial Engine, Low Oil Engine Shutdown, Hose & Lance Assembly Sold Separately
______________________________________
TS-2021 GENERAL PUMP 5.6 GPM @ 3,500 PSI
This is the REAL TS-2021-with the nickel plated head
Limited Quantities for $395.00
13 HP ZONG SHEN INDUSTRIAL ENGINE
Replace that worn out Honda with this incredible bargain.
While Supply Last - Only 8 Available! $239.95 (See pic below)
We ran this engine under load at 4 GPM & 3500 PSI
for over 100 hours non-stop and it performed flawlessly!
DUAL PUMPER SYSTEM
30 Horsepower Kohler Engine with 25 Amp Recharge
1 Gun at 3200 PSI AT 10 GPM-OR-2 GUNS AT 5 GPM RUNNING 3200 PSI EACH
List Price $9,995.00 -Typical Professional Discount $7,495.00
BUY NOW FOR $4,995.00
OFFER EXPIRES 6-30-2009
ONLY 5 AVAILABLE AT THIS PRICE (RED FRAMES)
(shown with optional heaters that can be added later and optional 40 HP Kohler)
__________________________________________________ _____
KOHLER ENGINE-PRE-ARRIVAL SALE
18 HP, Electric Start, Top Mount - Oil Filter Side Muffler
HOT WATER READY - with a 20 AMP Recharging System
Regular Price $1527.00
Now $899.00
This is an engine that we will be using for our new line of pressure washers that you will find in our catalog at www.envirospec.com
In order to be competitive we had to purchase a huge amount of these engines. We are making a limited quantity available at almost COST in order to free up space. This is a Pre-Arrival Sale which means you purchase your engine now and when they arrive from Kohler it will be shipped to you. Kohler is telling us to expect these engines in between the 15th and 31st of July, 2009. (maybe sooner)
BRIGGS ENGINE-In Stock - Ready to Ship
18 HP, Electric Start and Axillary Recoil Start, Low Mount Muffler
Regular Price $1203.00
Now $899.00
ALLISON IRON HORSE SUPER SKID-SUPER HOT WATER
18 HP BRIGGS, TS2021 PUMP, 3500 PSI @ 5.6 GPM
List Price: $7,995.00-Our Contractor Price: $5,495.00
$3,995.00 Vertical Coil
$4,195.00 Horizontal Coil
(Horizontal shown with optional Honda Engine - offer expires at 5 PM on 6/30/09)
INCREDIBLE BUY!
ALLISON IRON HORSE COLD WATER PRESSURE WASHER
18 HP BRIGGS, 3500 PSI @ 5.6 GPM, Gear Drive System
Configuration #1
18 HP Vanguard Engine, Pump, Gear Drive Transmission, Unloader
(This is one that you can bolt down to the floor of your vehicle does not include any base - 4-bolts will attach gear to engine)
GUN, LANCE, HOSE, INJECTOR, NOZZLES SOLD SEPARATELY
List Price: $3,495.00-Our Contractor Price: $2,695.00
Now $1,550.00
Configuration #2
18 HP Vanguard Engine, Pump, Gear Drive Transmission, Unloader on Cart
(This is one that is completely assembled on a rugged 2-wheel cart)
List Price: $3,995.00-Our Contractor Price: $2,995.00
Now $1,750.00
Configuration #3
18 HP Vanguard Engine, Pump, Gear Drive Transmission, Unloader on Base Plate
(This is a complete unit on a base plate that will bolt down to the bed of a truck or trailer)
List Price: $3,795.00-Our Contractor Price: $2,795.00
Now $1,690.00
Configuration #4 with 4-Drive Belts
18 HP Vanguard Engine, Pump, Belt Drive, Unloader on Cart
List Price: $4,195.00-Our Contractor Price: $3,195.00
Now $1,795.00
