Results 1 to 4 of 4
Thread: oxalic reclaim
    UAMCC Charter Member Comes A Time's Avatar
    Canton CT
    53
    Default oxalic reclaim
    I have a commercial job to bid cedar shake siding with cedar shake roof (dutch colonial style over a (covered ) brick walkway . concrete and pavement every where- no grassy surfaces . the customer wants it stripped and brightened , it has a old coat of semi trans oil , now I know I have to reclaim , what is the proper way to do this ?? cover storm drain , recover water ,filter through what kind of filter ?? I have acess to a sanitary sewer dump drain where a friend dumps his camper waste ?? is this workable ?? Thanks for the help Im a newbie , at reclaim and want to do it right .
    Marc Cournoyer
    Comes A Time Powerwashing
    35 Secret Lake Rd
    Canton CT 06019
    860-693-1465 H
    860-205-3516 C
    Senior Member
    In a house on a hill
    109
    Default Re: oxalic reclaim
    not sure on the specifics about how to tackle this, but if you need to borrow my vacuboom, you can use it.
    Gary Schell
    717-877-0459
    Canton CT
    53
    42 reviews and one reply ??wheres all the reclaim guys ?? thanks for the offer Gar
    Marc Cournoyer
    35 Secret Lake Rd
    Canton CT 06019
    860-693-1465 H
    860-205-3516 C
    UAMCC Charter Member Paul Kassander's Avatar
    Apr 2009
    188
    The Vacuboom would be a good simple choice for recollection.
    As far as treatment goes you are in essence neutralizing the chemicals when you apply the brightener to the wood so Ph should not be a factor. When you capture the water you will need to allow for some solids settling and treatment for any oils which you can do by floating some oil absorbent socks in the tank.
    For discharge you should be able to dump in the sanitary sewer after that simple treatment but you will need to check with the local POTW to be sure that is all they require, they may want to see your msds sheets as well.
