Results 1 to 7 of 7
Thread: soap
    Default soap
    Whats the best soap to use for fleet washing
    UAMCC Charter Member
    601
    Default Re: soap
    Quote Originally Posted by E-P-W View Post
    Whats the best soap to use?
    I switch between Ivory and Dial - I have always been suspect of that 99 and 44/100's pure - what do they mean, pure what?
    Daniel Tambasco
    Just Plain Painting
    Gutter Cleaning MA
    Deck Restoration Contractor
    978-749-9808
    Default Re: soap
    The two best soaps I have used are Panel Brite and STW-75.
    Industry Veteran Carlos's Avatar
    4,394
    Default Re: soap
    EPW - Welcome to the BBS. Please let us know who you are by going to the User CP (upper left corner) and fill out your signature line. Thank you and welcome again!!
    Industry Veteran Mathew Johnson's Avatar
    934
    Default Re: soap
    I have used truck wash supreme
    M. Johnson
    Pressure Washing Services, Inc.
    Send Email
    Property Cleaning Mobile Hotline 607-435-5539
    601
    Default Re: soap
    Ahh I see - you didn't write in fleet washing when I responded. I was worried for a second that Mr. Fenner uses panelbrite in the shower!
    Daniel Tambasco
    Just Plain Painting
    Gutter Cleaning MA
    978-749-9808
    Member Daniel H's Avatar
    East Tennessee
    48
    Default Re: soap
    I use a product called Brown Thunder from a local dealer it is based on panelbrite.. its awesome alittle better than panelbrite in my opinion.. I can take 1 drum and honestly make 11 drums.. and downstream it.. if I want it hot I put 7 gallons in a drum instead of 5.. I can do my aluminuim bright the extact same way... it is called TWT.. ( they made it for Tide Water Transportation)
    I am NOT pushing this soap on here... just telling what kind I use.
    A word of CAUTION when using panelbrite for the 1st time start weak then get stronger on the mixture.. this will save you a little heartache on the tanks cause it will burn the tanks.
