This is an email I got today, and it is a sales pitch, but it does raise some interesting points from a regulatory point of view. This is the sort of thing that can jump up out of the short grass to bite your business in the tenderest part...the wallet.
There is as much mis-information out there concerning DOT compliance as there is involving any other regulations, and the consequences of mistakes can be severe.
Anybody used these people, or seriously thinking of it?
The FMCSA has just published a list of 16 One Strike and You're Out violations. This final rule requires new entrants to comply with this regulation effective Feb.17, 2009 with a compliance deadline of Dec. 16, 2009. A violation found during the safety audit would result in automatic failure of the audit. What this means is any motor carrier will lose its authority if they cannot prove the violation was corrected within 60 days after the notification of failure, 45 days if they carry passengers or hazmat. Once the authority is revoked and an out-of-service order is issued and the new entrant will have to wait 30 days before re-applying for a new authority, starting the process over completely from the start.
The violations are as follows
- Failing to implement an alcohol andor controlled substances testing program.
- Using a driver known to have an alcohol content of 0.04 or greater to perform a safety-sensitive function.
- Using a driver who has refused to submit to an alcohol or controlled substances test required under part 382.
- Using a driver known to have tested positive for a controlled substance.
- Failing to implement a random controlled substances andor alcohol testing program.
- Knowingly using a driver who does not possess a valid CDL.
- Knowingly allowing, requiring, permitting, or authorizing an employee with a cdl which is suspended, revoked, or canceled by a state or who is disqualified to operate a commercial motor vehicle.
- Knowingly allowing, requiring, permitting, or authorizing a driver to drive who is disqualified to drive a commercial motor vehicle.
- Operating a motor vehicle without having in effect the required minimum levels of financial responsibility coverage.
- Operating a passenger carrying vehicle without having in effect the required minimum levels of financial responsibility.
- Knowingly using a disqualified driver.
- Knowingly using a physically unqualified driver.
- Failing to require a driver to make a record of duty status.
- Requiring or permitting the operation of a commercial motor vehicle declared ??out-of-service?? before repairs are made.
- Failing to correct out-of-service defects listed by driver in a driver vehicle inspection report before the vehicle is operated again.
- Using a commercial motor vehicle not periodically inspected.
There is too much at stake to leave this to chance. No one can afford to lose their authority or even have vehicles placed out of service for a short while. Learn what you need to know to avoid these violations by attending Online Trucker's two-day workshop. We will show you everything you need to know to comply with every federal regulation pertaining to operating commercial vehicles.
Speak to an associate about enrolling by dialing 1-877-595-4856 or direct 1-972-412-3453 from Canada or Mexico.
We will be hosting classes in these cities in 2009.
Feb 26-27 Los Angeles CA Aug 27-28 Los Angeles CA
March 26-27 Chicago IL Sept 24-25 Chicago IL
April 2-24 Dallas TX Oct 29-30 Dallas TX
May 28-29 Philadelphia PA Nov 12-13 Portland OR
June 25-26 Nashville TN Dec 10-11 Nashville TN
July 30-31 Jacksonville FL
